Email logins are now active ×
Weber idle jet size help needed...
swa240z
I have a set of triple 40's on my 240z that I'm trying to dial in.  I had a low RPM stumble that I cured by moving up in jet size from a 50F9 to a 55F9.  In the process of doing swapping idle jets, my idle mix screw is now only about 3/8 of a turn out and I'm having some rough idle issues and richness.  I'd like to try an idle jet that is right in between the 50F9 and the 55F9 but I'm not sure which one that would be - maybe a 55F8 or 55F2?  I've seen the chart showing the F# order from lean to rich (attached), but I don't know how a 50 series F chart compares to a 55 series F chart.  Is there any overlap or is it sequential?  BTW, the car runs great off idle.
Thanks!
Steve
Fuel height is an important parameter affecting the slow the off-idle transition to the mains as well as the fuel richness when cruising on the highway.
30mm down to 27mm down are optimal for Webers.  It is a critical tuning parameter.  It is important to balance the fuel height with a friendly sized idle jet to get the best performance for the off-idle transition and the air/fuel ratio at cruise.  The number of turns on the idle enrichment screw are not important and come after finding the best idle jet and fuel level.
here is a nice blurb on fuel height: http://www.classiczcars.com/topic/44512-setting-weber-dcoe-fuel-level-with-caliper/
Edited by 240260280
  • Who's Online   1 Member, 0 Anonymous, 221 Guests (See full list)
