hi,
what do you call the rubber mount that holds the strut that has 3 bolts. this is not really my question.
my question really is....
do these rubber(strut mount) are of equal height front(strut) and back(strut) ?
Originally posted by Ed
Those are the strut mount insulators. They are the same front and back. Only difference when assembled is the front ones have a bearing, the rears do not.
thanks, i ask the question 'coz i have a double height one that i got from the wrecking yard, and it confuses me which is which.
i have a 72
Could you cut some off the isolator to lower the body, or do you have to use those special isolators that were made shorter? It looks like a set of the shorter isolators and lowering spring should get you about 2 inches lower...
