Email logins are now active ×
floor board rust
Fun_in_my_z
Rusted floor and Z cars are vary common together. I had to replace the floorpan on the passanger side and I was able to repair the drivers side. I think part of the trouble was there had been a leak in the heater and water had been allowed to stand in the passenger side foot well. That or a leaking door seal. Either way t he factory supplied jute base for the carpet holds water like a sponge. I bought floor pannels from Zed findings. They are first rate , really. If you want pictures I can send them to ya I just need an e address. I dont know how to shrink them for the gallery. I cut out the rusted sheet metal with a saws-all and removed the seat supports with a spot weld cutter. I was going to be painting the whole car so I stripped out the entire enterior, and sand blasted the floor before the cutting. This is how I really found out how bad the rust was. My friend and I fitted the new pan in the space after the cutting and removing of the bad sheet metal. We held the new floor in place with self tapping sheet metal screws . They ended up being about 4" apart all around the perimeter of the floor. Some minor cuts were made in the new pan to form and fit the space. This was then tig-welded by a welder and the holes filled as the screws were removed. Dont cut any metal away untill you have the replacement in hand so you can see what to leave.
