Posted March 1, 200223 yr comment_3500 Another question. Is the gauge on the dashbord acurate? What should be the reading? Link to comment https://www.classiczcars.com/forums/topic/1004-oil-pressure/ Share on other sites More sharing options...
March 1, 200223 yr comment_3504 Is it accurate? Maybe or maybe not! First check your oil level! I have heard of gauges acting up but usually a problem with the oil reading is the sending unit. My motor is not stock and I have a ZX high volume oil pump so the reading may be different from yours. I usually see a reading of about 1/2 at about 2000 RPM and it usually goes up to 3/4 or a little more when on the freeway, between 2800-3500. Over that I am usually watching my mirrors more than the oil gage! Is mine accurate? I don't know but it seems to work okay. Link to comment https://www.classiczcars.com/forums/topic/1004-oil-pressure/#findComment-3504 Share on other sites More sharing options...
March 1, 200223 yr comment_3506 In my opinion the only truly accurate oil pressure gauge is a mechanical one. I have had Z's that showed 0 at idle and some that showed almost pegged the gauge at idle. Not only is the gauge somewhat innacurate the sending unit is always suspect. Sorry, never trusted anything electrical(especially in a car that is now over 30 years old) so the only way to find out is to take a reading of the stock gauge and then check the oil pressure with a mechanical one and see how much difference there is. You can pick up a decent mechanical gauge at an auto parts store for 20 bucks or so and hook it up temporarily and go from there. Why take a chance on ruining an engine whe you could have saved it for 20 dollars? Link to comment https://www.classiczcars.com/forums/topic/1004-oil-pressure/#findComment-3506 Share on other sites More sharing options...
March 1, 200223 yr Author comment_3512 Well said and a good advice, but I might use the car as a dayly driver this summer, so was my point for asking that. And yes, I usually check my oil level on my Sentra SE once a week, but I guess I will have to be more careful with my baby Z. Link to comment https://www.classiczcars.com/forums/topic/1004-oil-pressure/#findComment-3512 Share on other sites More sharing options...
March 4, 200223 yr comment_3582 I was sitting in the inspection line, and I noticed that the oil guage was reading 0 at low (8-850 rpm) idle. WHAT?!!?? heart attack time. I raced the engine and the needle came up. I failed inspection, so my mind was not on the oil on the way home. Guess I have to pick up a mechanical guage. At 2K rpm, the needle is about a third to half. Glad I found this thread.peter73 240 Link to comment https://www.classiczcars.com/forums/topic/1004-oil-pressure/#findComment-3582 Share on other sites More sharing options...
March 5, 200223 yr comment_3604 Peter, you could just try a new sending unit, they have a tendancy to get gummed up with sludge for one reason or another. It is fairly cheap, however it will never be as accurate as a mechanical gauge. Link to comment https://www.classiczcars.com/forums/topic/1004-oil-pressure/#findComment-3604 Share on other sites More sharing options...
