Posted February 5, 200421 yr comment_67205 I was just curious what the point of the coolant lines were on the carbs. I have not seen them before, but only dealt with down draft carbs in the past. Is this to keep them cool from the exhaust manifold right below?On another not many of the coolant lines on my carbs are cracked or leaking. Can I just replace these with regular coolant hoses or do I need to protect them somehow for the heat?SuDZ Link to comment https://www.classiczcars.com/forums/topic/10060-coolant-lines-on-carbs/ Share on other sites More sharing options...
February 5, 200421 yr comment_67213 Originally posted by SuDZ I was just curious what the point of the coolant lines were on the carbs. I have not seen them before, but only dealt with down draft carbs in the past. Is this to keep them cool from the exhaust manifold right below?On another not many of the coolant lines on my carbs are cracked or leaking. Can I just replace these with regular coolant hoses or do I need to protect them somehow for the heat?SuDZ On 240Z's the coolant flow through the intake manifold and carbs was to heat the carbs quiker upon "cold starts". After a certain temperature is reached, there is a valve that closes to shut off the colant flow.I would asume that the purpose is the same on 260Z's with the "bodanker" carbs. Link to comment https://www.classiczcars.com/forums/topic/10060-coolant-lines-on-carbs/#findComment-67213 Share on other sites More sharing options...
February 5, 200421 yr Author comment_67229 Originally posted by Bambikiller240 On 240Z's the coolant flow through the intake manifold and carbs was to heat the carbs quiker upon "cold starts". After a certain temperature is reached, there is a valve that closes to shut off the colant flow.I would asume that the purpose is the same on 260Z's with the "bodanker" carbs. Now for replacing the lines there with regular lines from the parts store - do you think that would be fine or would I have to wrap them with a "Heat Wrap" kind of material?SuDZ Link to comment https://www.classiczcars.com/forums/topic/10060-coolant-lines-on-carbs/#findComment-67229 Share on other sites More sharing options...
February 5, 200421 yr comment_67234 Originally posted by SuDZ Now for replacing the lines there with regular lines from the parts store - do you think that would be fine or would I have to wrap them with a "Heat Wrap" kind of material?SuDZ "Normal" water/coolant line should be fine. They weren't covered in a heat wrap from the factory. Link to comment https://www.classiczcars.com/forums/topic/10060-coolant-lines-on-carbs/#findComment-67234 Share on other sites More sharing options...
February 6, 200421 yr Author comment_67330 Originally posted by Bambikiller240 "Normal" water/coolant line should be fine. They weren't covered in a heat wrap from the factory. Okay thanks. I guess at some point in my cars history someone thought they needed to be. They have what looks like header wrap around them. It is pretty old looking so I was not sure if this was an original item or not.Thanks again Carl.SuDZ Link to comment https://www.classiczcars.com/forums/topic/10060-coolant-lines-on-carbs/#findComment-67330 Share on other sites More sharing options...
