Posted February 10, 200421 yr comment_67914 Today I went to look at a 1970 L24 and was unable to identify what type of head it had. The only thing that I noticed was a stamp on the block saying E31. Does that mean that the head is also a E31 or ....... Can some one help Link to comment https://www.classiczcars.com/forums/topic/10132-identifing-engine-type/ Share on other sites More sharing options...
February 10, 200421 yr comment_67936 The head will definitely have an identifying label on it. Mine was located between the 1st and 2nd spark plug. e.g. look around where the red ring is. Link to comment https://www.classiczcars.com/forums/topic/10132-identifing-engine-type/#findComment-67936 Share on other sites More sharing options...
February 11, 200421 yr comment_67941 TTDRIVER, You were looking right at the head casting stamping (which is which head you have). The block casting stamp is on the flat boss to the left (of red circle below #5 spark plug.) and just below the block deck. These are L24, L26, L28, followed by serial numbers. TT it looks like you have the original motor/head, if the block is stamped L24. the head is a rare (now) early head. Link to comment https://www.classiczcars.com/forums/topic/10132-identifing-engine-type/#findComment-67941 Share on other sites More sharing options...
February 11, 200421 yr comment_68031 TT driver,As Frank13 said the head is correct for the car,with L24 stamped,its the correct "size" block for car....I respectfully add that the numbers following the L24 should match the metal information tag screwed to the passenger side strut tower,inside engine compartment 99% of the time. The VIN # on that same tag should also match the VIN number stamped on firewall to be the original engine for that car....I've been surprised over the past week or two, of the number of people that aren't truly aware of how to determine what engine is supposed to be sitting in their engine bay.David Spillman Link to comment https://www.classiczcars.com/forums/topic/10132-identifing-engine-type/#findComment-68031 Share on other sites More sharing options...
February 12, 200421 yr comment_68113 Very true dspillman! My oversight. :devious: Link to comment https://www.classiczcars.com/forums/topic/10132-identifing-engine-type/#findComment-68113 Share on other sites More sharing options...
