Snapping Wire Splice blocks?
bobbovine
My '74 260z has a busted washer bottle pump. The assembly is proving very difficult to locate, so I'm probably going to go with a 240z bottle/pump. The only problem is the wiring connector is different. The 240z has two spade type connectors while the 260z has a socket style. A while back I remember seeing these little plastic snap together wire splicing blocks. It has two channels, one wire goes in one, the other in the second channel, you snap it closed and little spade blades cut through the casing and bridge the two wire.
Does anyone else know what I'm talking about? I can't remember what they're called. I'd like to use two to put the old connector on the new pump.
Thanks
  • Who's Online   1 Member, 0 Anonymous, 560 Guests (See full list)
