Loss of power after high speed run
Murph
Dato,
Don't forget linkage check to assure even opening of both carbs.....visual check should rule it out ....uneven airflow,linkage issue or bent valve.
Long shot,but plug brake booster line at crossover to rule out leaky check valve,line or brake booster. just thoughts.:cross-eye
david
Linkages are good, carbs open together. Previously I'd pulled the brake booster line and plugged the hole, and it seems to run exactly the same.
I'd say at this stage I'll be chasing up blockages in the fuel line/fuel pickup and valve adjustment.
Thanks for all the suggestions everyone, greatly appreciated.
I just had a similar problem with my 73 240Z. The car was running great, then after a high speed freeway run, it start to surge and idle very poorly and sickly sounding. I replaced both fuel filters, nothing. The adjusted carbs(dual webers) nothing. Finally replaced the cap and rotor, and have not had a problem since. Even though they did not look worn or damaged, they were the cause.
I've just put it back together and WOW! The motor is so quite and smooth! I've always commented on the amount of mechanical noise from the engine and it's always had a tick from the top end.....now no more tick, and it's virtually silent! Generally runs a bit smoother and a little stronger. Idle is still a bit lumpy, but not too bad. Gotta do a 20min drive tonight, see how she goes.
Thanks for all the help everyone! :)
Be careful when you undo the lock nuts if they're tight! One of the ones on cyl 6 was pretty damn tight and when it did go I smashed the knuckle of my index finger into the top edge of the block, which made a nice 1cm long gash to the bone. This is bad. ROFL
Anyhow, do them cold as it will take a while your first time. Just give it go, not too hard at all, you'll get the feel for it pretty quickly.
  • Who's Online   0 Members, 0 Anonymous, 437 Guests (See full list)
