Rear disc convo, couldn't find the right help!
Walkingpig
Hello all,
I searched here and Hybrids,
couldn't find what i was after,
i'm wondering what the simplest rear disc upgrade is on a Z, is there such a thing as a bolt-on swap for something like a skyline or 280zx?
. alternatively, what shoudl i be chasing down for the easiest swap, and what is involved in getting them on and working (including hand-brake)
THanks in advance! Charles
The question really deals with money and how much you want to spend.
I am doing the late maxima brackets with 240sx calipers and 1984 300ZX rotors. The late 280 ZX calipers will also work with these brackets, but there is a lot of negative comments floating around as to there durability.
Several companies including Ross Corrigan/Modern Motorsports, Motorsports Auto and fonebooth. com all have versions of this. They use a fabricated bracket (Aluminum) and either the 240sx or 280ZX calipers. The Maxima brackets (Cast Steel) are hard to find and harder to remove.
modern-motorsports@shaw.ca
http://www.zcarparts.com/
http://www.fonebooth.com/auto.html
Check the "Z Car Homepage". Home of the Internet Z club, there are a couple of tech articles. The Hybrid Z search engine is down at the present due to band width issue with the host. Soon to be rectified.
Good luck.
ecp48
