Posted February 18, 200421 yr comment_68986 Hey there guys,I can get an R200 LSD from an R31 Turbo Skyline, now.. theoretically the powerplant has changed, did that also include any changes to the drivetrain or would I be good to go with an R200 from an R31 in my C110?And if it all adds up, what other bits and pieces would I need? Link to comment https://www.classiczcars.com/forums/topic/10258-skyline-r200-diff-r31-c110/ Share on other sites More sharing options...
February 18, 200421 yr comment_69024 I was under the impression all R31 diffs were solid axle, not like the R series ie R160, 180, 200, etc. I stand to be corrected though.... Link to comment https://www.classiczcars.com/forums/topic/10258-skyline-r200-diff-r31-c110/#findComment-69024 Share on other sites More sharing options...
February 18, 200421 yr comment_69028 I think all R31's which came to Australia had a solid rear end, but I am pretty sure there were at least some of the japanese models which were fitted with an IRS rear end, and NZ is the king of grey imports, so you could get lucky. Link to comment https://www.classiczcars.com/forums/topic/10258-skyline-r200-diff-r31-c110/#findComment-69028 Share on other sites More sharing options...
February 19, 200421 yr comment_69031 my R200 is out of an r 31 skyline GTS straight bolt in to a Z.not sure if the GTS was any different in the rear than the standard car. Link to comment https://www.classiczcars.com/forums/topic/10258-skyline-r200-diff-r31-c110/#findComment-69031 Share on other sites More sharing options...
February 19, 200421 yr comment_69034 By the sounds of things it sounds as though the R31GTS models had different rear end set ups, was probably just the base 'executive' versions that came out with solid rear.Interesting... Link to comment https://www.classiczcars.com/forums/topic/10258-skyline-r200-diff-r31-c110/#findComment-69034 Share on other sites More sharing options...
February 19, 200421 yr Author comment_69039 Quote Originally posted by Brett240 my R200 is out of an r 31 skyline GTS straight bolt in to a Z.not sure if the GTS was any different in the rear than the standard car. Do you know what ratio is used in the R200 in Skylines? Link to comment https://www.classiczcars.com/forums/topic/10258-skyline-r200-diff-r31-c110/#findComment-69039 Share on other sites More sharing options...
February 19, 200421 yr comment_69049 no idea, mine had a 4.4 in it beofre i swapped for a 3.9it was originally out of an R31 before being briefly used in a 240z drag car, hence the 4.4i'd be suprised if the skyline didnt use either a 3.7 or 3.9 Link to comment https://www.classiczcars.com/forums/topic/10258-skyline-r200-diff-r31-c110/#findComment-69049 Share on other sites More sharing options...
