I might be wrong but usually it means that the front sidemarkers,emblems and any other object is removed and covered up so that its seem's as if there wasn't anythig there. Some people like the way it looks, it all depends on you. If you are looking for a Z to keep original I wouldn't consider the one your looking at. It still can be converted back to the way it was but it requires alot of body work. Hope that helps.
https://www.classiczcars.com/forums/topic/10360-classifies/#findComment-69679
