engine
Fun_in_my_z
Ok no need to feel bad you don't know. The P30 would indicate an earlier style block definately l26 or l24.
On the right hand side of the motor opposite the intake and exhaust manifolds.
There should be a number stamped onto the block starting with L24 or L26 that will indicate your engine size.
I believe above that will be a head stamp saying E88 most likely let me know if it's otherwise.:classic:
