I am getting a 1971 240Z with an automatic transmission (it doesn't work, slips too much). I am also getting a manual transmission with it (with flywheel, clutch, pedals, etc). Here are my questions:
I know that it will bolt right up to the engine, but what about the driveshafts? Is the length different for the two transmissions?
Also, does anyone know where I could get the manual tranny mounts?
Last thing, where is the best place to get a slave cylinder for it?
Thanks for your help guys!!
is it full of trans fluid? sorry just had to ask... is the fluid brown and burned smelling,.
anyway get a slave cyl from the parts store they are cheap, you could also get a tranny mount from the parts store to, and if your going to put a five speed in i would search a little bit and find out if itll fit int right there is some mod to be done to the early cars trans tunnel do to the shifter, it will fit if you get it from, a 70-83 not turbo z car (please correct me if im wrong) you should take the tranny mount from there to ensure you get the right on at the store.
I've searched, but haven't found much about the automatic transmission. (guess its not that popular!) ;)
So, from what I've read, everyone thinks that the driveshaft is the same length for either tranny?
If so, I am in luck! If not, I'm in trouble...
Thanks for the posts!
Really sorry i have absolutely no idea. I have never owned an automatic but if your desperate to know i guess i could call someone or ask a mate who has worked on many Z cars.
Otherwise just pull a shaft out of a junk yard Z with a manual transmission.
Back in about 1978, I took a '71 240Z with an automatic, and dropped a 4 speed into it. I'm 99% sure I didn't have to replace the driveshaft. That 1% is just because it's been a LONG time! I remember that I forgot to get the flywheel from the junkyard and had to go back, but was amazed that the pedel brackets and clutch master cylinder hole in the fire wall were already there in the car. I should have changed out the distributor too, so I wouldn't have had to deal with the dual points, but I didn't...
So, sorry it isn't a definite, but it's REALLY close to one!
A 99% is much better than what I had before! Thanks! I am getting the flywheel, clutch, pedal, master cylinder and the tubing with it. (just need to get the slave)
So, thanks again!
P.S. If anyone knows that this is wrong, please let me know. Otherwise I will take this as "your final answer." :)
Thanks for the reply US240Z.
Do you mean that the tranny mount and the drive shaft from the automatic tranny fit the manula tranny?
Or do you mean that you swapped in a new driveline and mount with the manual?
I just want to clarify to be extra sure. Thanks again!
