HID Headlights w/ City Lights
EScanlon
I found these on e-Bay and although not billed as the same thing as what I have, they appear very similar to mine. The biggest diference is that mine have 2 bulbs for the extra light and not just the one.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=2463105556&category=33710
Hope this helps someone.
Enrique
  • 3 weeks later...
(qoute)The biggest diference is that mine have 2 bulbs for the extra light and not just the one.
Enrique - it does have two bulbs the HID 130W and a 5W "city light"
(quote)the city light thing doesn't sound bad, especially if it helps you see around a corner. Is that what it does?
Tomohawk - The city light is just a very dim (5W) bulb that probably isn't legal anywhere in the states for night driving but are representitive of day time running lights
What I meant by the 2 vs 1 bulb, is that the ones on e-bay currently show that there is only ONE bulb for the City Light portion of the lamp, whereas the lamps I bought have TWO bulbs.
Now, in addition to those bulbs, which are the ones that create the "halo" effect, are a set of "Xenon" gas H4 lights, meaning that they aree the replaceable "halogen" style of lamps. They are brighter than the original lamps, but don't know how much more so.
I wired my Halo's to operate with the Parking Lamps, that way at dusk when I typically run with the Parking Lamps on, they would be illuminated. I'm not sure if the single bulb in the ones on e-bay would light it up enough to provide a "halo".
Bill is correct in that they are just a pair of 5W side marker bulbs and not designed to light up the street. Their function is to look cool!
2¢
Enrique
Are there any ACTUAL HID conversions available for the Z car? I love the look of HIDs, and more importantly, I love being able to see at night (Had a bad accident due to poor visibility one time...never make that mistake again).
TomoHawk,
Just out of curiosity, how did you arrive at 12a/11.5a!??? Maybe a typo? Watts divided by volts equals amps. Or volts times amps equals watts. Would it not be as follows....85w @ 7.0amps / 80w @ 6.67amps?
