March 5, 200421 yr Author comment_71250 So on that picture (and on the blower harness) there's the connector that connects to the blower speed control switch, and branching off from that is a little 3-prong white plastic switch with two wires coming out of it, blue and red. Now, where does THIS plug into, and am I at all close in assuming this is the power? Being red and all...if this is the power, it might explain why I have no power to the blower...as this connector isn't plugged into anything in my car. Link to comment https://www.classiczcars.com/forums/topic/10519-well-this-blowsnot-really/?&page=2#findComment-71250 Share on other sites More sharing options...
March 5, 200421 yr comment_71271 First, take a look at the picture I'm attaching. I "borrowed" it from the e-Bay auction. Enrique Link to comment https://www.classiczcars.com/forums/topic/10519-well-this-blowsnot-really/?&page=2#findComment-71271 Share on other sites More sharing options...
March 5, 200421 yr comment_71275 Ok, with that picture I hope you can address whether you need that wiring harness or not.Now, as far as wiring schematics are concerned. They are fine if you know where to find the individual wires that are represented by the wiring schematic. Unfortunately, the majority of schematics do NOT identify which wires are together. An exception to this is the later schematics for the 260 and 280. However, those have their own level of incredible complexity tossed in as to make them totally unuseable.The FSM does have a Multiple Connector Diagram as well as a Single Wire connector diagram. Those in hand with the wiring schematic are a good set to decyphering out the wiring.So, hope all this helps.Enrique Link to comment https://www.classiczcars.com/forums/topic/10519-well-this-blowsnot-really/?&page=2#findComment-71275 Share on other sites More sharing options...
March 6, 200421 yr Author comment_71431 Will take a look at the wiring tomorrow morning, but if memory serves me correctly, that power lead and ground wire are simply not there on my car. That might explain why the blower isn't getting power =D Link to comment https://www.classiczcars.com/forums/topic/10519-well-this-blowsnot-really/?&page=2#findComment-71431 Share on other sites More sharing options...
March 6, 200421 yr Author comment_71517 Last night, after working from 7:30am till 1:30am, an idea came to me right as I fell asleep. I woke up, showered, and went down to the garage...touched two wires together, and voila. I have a functional blower. Many thanks to Enrique and others for ALL the help (it's been a long, voltmeter-filled journey), and I'm ecstatic...now the real fun begins! Now that the cars lights and signals and such work, it's time to take it into work and change gaskets and boots, seals, bushings, pads, etc. Then off to the body shop for a new rear panel and paint...then into my hands for a daily driver! I'm SO excited. Oh man!!!!! I love this car, and I LOVE this board. =D Link to comment https://www.classiczcars.com/forums/topic/10519-well-this-blowsnot-really/?&page=2#findComment-71517 Share on other sites More sharing options...
March 6, 200421 yr comment_71519 I'm glad you got a "charge" out of it. Remember to document what appened. See if you can locate the spot on a wiring diagram for the next guy wioth the same problem. I even have a notebook with all the different circuits with colors, connector types, etc. drawn in it, when I work on that circuit. Link to comment https://www.classiczcars.com/forums/topic/10519-well-this-blowsnot-really/?&page=2#findComment-71519 Share on other sites More sharing options...
March 7, 200421 yr Author comment_71541 My problem, unfortunately, appears to have been entirely caused by a PO, or I would have a nice write-up with pictures, too. So much slicing and dicing behind my dash that I can only guess at what made him/her do it...the important thing is that it works =D Link to comment https://www.classiczcars.com/forums/topic/10519-well-this-blowsnot-really/?&page=2#findComment-71541 Share on other sites More sharing options...
March 7, 200421 yr comment_71550 I have a mysterious wire on my car too. I should chase it down this summer when my nerves settle down (too anxious to get my POWER STEERING working)Electrical stuff is next on the list because it won't cost a lot, but time. Link to comment https://www.classiczcars.com/forums/topic/10519-well-this-blowsnot-really/?&page=2#findComment-71550 Share on other sites More sharing options...
