Posted March 3, 200421 yr comment_71034 Is there a seam weld just above the quarter glass on our Z cars? Vicky Link to comment https://www.classiczcars.com/forums/topic/10538-is-that-a-seam/ Share on other sites More sharing options...
March 3, 200421 yr comment_71043 Sure enough! In fact, a lot of the Z's have what appears to be a crack at this seam, caused from years of chassis flex. Link to comment https://www.classiczcars.com/forums/topic/10538-is-that-a-seam/#findComment-71043 Share on other sites More sharing options...
March 3, 200421 yr comment_71046 Hi Vicky, I bought a 72 and it had been hit in the front so bad that the seam you described on my car's right side had split and had a quarter inch gap under the previous owners crappy repair job. When the hatch was closed you could see through the gap from the body being sprung. I suspect that is where the factory welded the roof on. Link to comment https://www.classiczcars.com/forums/topic/10538-is-that-a-seam/#findComment-71046 Share on other sites More sharing options...
March 3, 200421 yr comment_71047 Vicky,That seam laps multiple sheets of stampings and on the early cars is a real lead filled joint. Link to comment https://www.classiczcars.com/forums/topic/10538-is-that-a-seam/#findComment-71047 Share on other sites More sharing options...
March 4, 200421 yr comment_71091 And proves to be yet another spot which likes to rust away! Link to comment https://www.classiczcars.com/forums/topic/10538-is-that-a-seam/#findComment-71091 Share on other sites More sharing options...
March 4, 200421 yr Author comment_71147 Quote Originally posted by 26th-Z Vicky,That seam laps multiple sheets of stampings and on the early cars is a real lead filled joint. Chris,Would that include all Z's up to 78?Vicky Link to comment https://www.classiczcars.com/forums/topic/10538-is-that-a-seam/#findComment-71147 Share on other sites More sharing options...
March 4, 200421 yr comment_71161 Yup, the rear quarter and roof panels/door frames on all the cars up to 78 meet in the same place. In fact, I'd imagine even the ZX's have a seam in the same basic location as well. Link to comment https://www.classiczcars.com/forums/topic/10538-is-that-a-seam/#findComment-71161 Share on other sites More sharing options...
March 4, 200421 yr comment_71177 Vicky,Yes probably as my parts fiche lists superceed numbers up to 12 / 79. It gets quite confusing, but just dealing with the right side of the car, and both inner and outer panels are involved, the outer panels are:73120-E4100 - roof panel73270-E4100 - tail rail78100-E4600 - rear fenderThere are a number of inner panels as well as a corner brace involved that make up the box section through that area. I could look, but I'll bet there is an inner panel seam to match the outer. In my Chassis and Body Service Manual, this area is described through section E-E of Figure BF-59 "Sealing Body Panel Joint" and appears on page BF-31. Of course, this is all early series information, but it seems to be all the same up to 1979.I have had this area down to bare metal before and the seam in Her Majesty is filled with lead. It does crack and heating the area is done to fill it again. Link to comment https://www.classiczcars.com/forums/topic/10538-is-that-a-seam/#findComment-71177 Share on other sites More sharing options...
March 15, 200421 yr comment_72691 Here's a pic if the front a pillar on my '73 after getting it back from the media blaster. I never realized there was lead there! Link to comment https://www.classiczcars.com/forums/topic/10538-is-that-a-seam/#findComment-72691 Share on other sites More sharing options...
