71' 240z, 350v8, cage, immaculate condition, tx, MUST GO
Lazy-Z
http://home.houston.rr.com/tbserv/1.jpg
http://home.houston.rr.com/tbserv/2.jpg
http://home.houston.rr.com/tbserv/3.jpg
http://home.houston.rr.com/tbserv/4.jpg
http://home.houston.rr.com/tbserv/5.jpg
http://home.houston.rr.com/tbserv/6.jpg
http://home.houston.rr.com/tbserv/7.jpg
http://home.houston.rr.com/tbserv/8.jpg
http://home.houston.rr.com/tbserv/9.jpg
http://home.houston.rr.com/tbserv/10.jpg
http://home.houston.rr.com/tbserv/11.jpg
Here is a list of the complete mods and a link to the pictures.
1971 Datsun 240z chassis in immaculate condition
Straight Frame
clear title
registered
Chassis:
The lighter of the Z bunch ~2100lbs
10-point TIG welded cage (set-back harness bar for seat clearance)
Widened rear fenders about an 1" (cut and tig welded)
4" fiberglass cowl grafted on fiberglass hood (perfectly matches the line of the 'stock' hood)
Fiberglass front and rear bumpers
aftermarket front bumper available (MSA with brake ducts)
Motor bracket/mount is set back 1 more inch than the JTR set up, custom crate/mount welded from the rails to motor mounts
Hairpin Hoodpins
Shaved Emblems
Suspension:
Rear Chromoly A-Arms with adjustable ends
Rear Coilovers with 200# Springs
Shocks changed 1/2 year ago (forgot what brand, non-adjustables)
Interior:
Full assortment of Autometer gauges (Tach, Speedo, Oil, Water, Fuel)
Half Dash Cap
Procar leather bucket seats
Custom fuel fill under rear carpet
5-point harness
Fuel System:
8 gallon fuel cell with sump and custom fuel level sender (cut out spare tire well and welded in rails for mounting)
-8AN braided lines
inline filter
Mallory 140gph pump
Mallory FPR
Return to cell
-6AN line from FPR to carb
Motor: (Has NOT been raced or even abused)
Stock rebuilt SBC 350 ~2600 miles
650CFM Edelbrock carb elec. choke
Filter Spacer
69' corvette cam
Edelbrock Performer intake
billet pulleys
aluminum water pump
hooker headers block huggers
copper crush gasket
1200* plug wire covers
Exhuast System:
2.5" to 3" crossover;
to dual 3" in/out glasspacks;
to dual 3" out the rear bumper
Cooling:
26x19 Howe radiator
160* Thermostat
Stant Cap (16-18lbs. street)
Larger hoses (1.5" and 1.75")
black magic fan
water wetter
Electrical:
Mallory VI-AL electronic ignition with rev limiter
Mallory Coil
Mallory unilite distributor
Quick Disc. battery terminals
780 CA Battery
Remote Terminal
working headlights/taillights/signals
3 switches mounted in cut and rolled sheet in dash where radio a/c goes
push-start
108Amp 3-wire alternator
Transmission:
700r4
JTR Transmission bracket
carb adapter for TV cable
Lokar tranny dipstick
hurst quarter stick shifter
-6an cooler hoses to perma-cool frame rail cooler
leaks (possibly from gasket)
Rear end:
Solid mount
Driveshaft Hoops
R200 conversion
3.55 gears
Brakes:
Toyota 4x4 front caliper conversion up front
wheels:
14" centerline auto/drag
1/4" wheel spacers
longer studs in the rear
Need:
work on transmission
interior carpet
paint on rear quarter panels
$7400 OBO. Over $10,000 Invested! Deal of a lifetime!
old price was $7400, now asking $6900!
Why so cheap? Needs transmission work. Current one is leaking (could be from t.v. cable; level checker; or cooler lines) and I have not tuned the kickdown cable. Brake and clutch pedal+brackets also with the car if you go manual. Easy swap to do, I don't have the time to do it! 47 hour/week schedule prevents me from anything. Car starts, and runs as is! Trans. will shift and drive fine, will not downshift at WOT.
College student in need of money, help a guy out! I don't even take this beast out because I'm scared it might get a dent.
Located in Houston, Tx
Great basis for a street, weekend, or all out dragster!
Thank you for your time,
Steven M.
You can e-mail or call me directly on my cell phone, please leave a message if I am unable to answer the phone. I prefer to talk on the phone.
Sleeper-Z@houston.rr.com
281-948-3086
Only two things I dont like about it is sorry, but you know opinions, there like "A" holes everyone has them.
Mine is the cowl hood look on a Z just doesnt really fit, me personally I never did like them at all.
Second should have went with a 5speed.
Besides that a truely gorgeous conversion.
Looking for $6500.
I drove her today and she drove fine. The tranny just feels like that leak is not making it shift so well. It is not leaking now, but once you fill up the tranny to a certain point, it then leaks. there is currently fluid in there though.
thanks,
steven
Originally posted by sblake01
I don't think you should be concerned. It looks like his only reason for being here it to sell the car. :disappoin
Actually sir, I've been around and have been doing the right thing; by searching before I ask, therefore my post count is low. If you feel like attacking me, leave it to the PM's or e-mail. If I was a Z guru, or had alot of questions that have never been answered I'd have a higher post count. But now, i have a 47hr./week school schedule and am working on getting my scholarships either wise I won't be going to school. I need something that will get me to point A to point B without worrying if my car is going to get scratched or dented. This is too nice of a car for a 17 year old to have, which is what I am. Maybe when I'm out of college and have time to build a car like I want to and trailer it everywhere...
Lazy-Z
Is that your Z in my avitar?
If it is, I hope you dont mind me using it, I found it on Kazaa!
Cheer'z'
Chris
Yes, that was it with the old motor, use to run a 9.90 on open diff. and 250 shot.
Thanks for the comments?
Steven M.
[Yes, that was it with the old motor, use to run a 9.90 on open diff. and 250 shot.
Steven M.
Lazy-Z
What is an open diff? Is that one drive wheel or LSD? What does the car run now with the different motor? I would love to have V-8 Z, but my husband gets PO'd at the very mention of "Why didn't you put a V-8 in your Z". He likes to prove that the Z's inline six, when built properly, is quite capable of producing horsepower.
Vicky
P.S. The car you are selling looks very nice.
Yes, one drive wheel. With the different motor, i really don't know, because of the tranny i haven't put the pedal to the metal yet so i couldn't tell you. I'm estimating low 13's.
the inline 6's are very stout and quite quick. My friend down the street is capable of building a very strong and reliable l28 motor.
thanks,
steven m.
