NEW BABY FORCES SALE
1972 Datsun 240z built to ITS Class Spec with 24' open trailer for sale $5400 (located in NORTHRIDGE, CA). Car is rust free.
MORE PHOTOS ARE IN MY GALLERY... CHECK THEM OUT.
Please email for any questions
MOTOR & DRIVETRAIN
· 240Z engine std bore cylinders honed within spec, new rings, rod bearings, & main bearings. (built for ITS)
· Rebuilt 240Z 4-speed “b-box” with new 280Z clutch and pressure plate (zero miles on clutch & P.Plate
· Rebuilt E31 cylinder head (w/ new Cam)
· Rebuilt carbs w/ new fuel lines
· Electronic ignition
· Large Radiator, new hoses, new H2O pump, overflow tank, & Electric fan (on switch)
· New Transmission and Diff mount
· Welded exhaust system
BRAKES
· All new calipers, pads, & rotors
· All new drum brakes & shoes
· New steel-braided brake lines
· New Master cylinder
· Disk brake air ducting
SUSPENSION & TIRES
· Ground Control Coil-Overs w/ Camber kit
· Tokico 5-way adj shocks
· New tie-rod ends & Ball joints
· Front sway bar (rear not installed)
· New Tension Rod Bushings
· New Steering Bushings
· 14x6 Aluminum Race Wheels & Tires (Toyo)
SAFETY
· 6 point Autopower bolt-in roll cage
· 15Gal Fuel Cell with fume enclosure w switched electric fuel pump
· 2 Kill-Switches installed (Dash & Cowl)
· Mounted Fire Extinguisher
· Wrap around Racing Seat
· Window net
· Fresh air plumbing
TRAILER ($800 IF SOLD WITHOUT THE CAR)
· 24' Industrial strength dual axel
· Includes 2 wheel straps & Class 3 ball
· Has a 6’ x 6’ open box for tools, jack, tires, ect...
EXTRAS/SPARES
· 240Z engine block, Crankshaft, & Head
· Fiberglass rear spoiler (not installed)
· Rear sway bar (not installed)
· Bunch of other stuff - too much to list
· 14x7 Aluminum Wheels with street tires (For transport to and from events)
1972 Datsun 240z built to ITS Class Spec with 24' open trailer for sale $5400.
  • 1 month later...
  • 3 weeks later...
