Posted March 8, 200421 yr comment_71803 Hey guys, i had just finished fixing my fuel pump, so i took it off the stands and decided to fire her up. So i got my mom out and she watched cause she really wanted to see, i started it and it sputtered, sputtered and popped then after a couple tries i started! after 3 seasoned mechanics had tried i actually fixed it. But thats not the funny part, as i gave it some gas somthing came out of the tail pipe.....DOG FOOD!!?? yea, funny how the mice store there food everywhere.....it was a site, looking back and seeing dog food firing out the back. But i got it started, thats the important thing. Link to comment https://www.classiczcars.com/forums/topic/10628-you-guys-gotta-hear-this/ Share on other sites More sharing options...
March 9, 200421 yr comment_71834 Are you sure someone didn't "recharge" your catalytic converter? Then again, how many miles do you get to the bag? Or, maybe the PO thought you had to feed it back there in order to get the engine to "growl"...... ta da pum pum..... :stupid: Link to comment https://www.classiczcars.com/forums/topic/10628-you-guys-gotta-hear-this/#findComment-71834 Share on other sites More sharing options...
March 9, 200421 yr comment_71841 How does it run? Dare I say....... like a dog? Link to comment https://www.classiczcars.com/forums/topic/10628-you-guys-gotta-hear-this/#findComment-71841 Share on other sites More sharing options...
March 9, 200421 yr comment_71842 And you guys tell me not to be mean! Link to comment https://www.classiczcars.com/forums/topic/10628-you-guys-gotta-hear-this/#findComment-71842 Share on other sites More sharing options...
March 9, 200421 yr comment_71908 At least he didnt have mice living in the air cleaner box. They dont like getting sucked into the carbys. Chewed right through the air cleaner the little bastards. Link to comment https://www.classiczcars.com/forums/topic/10628-you-guys-gotta-hear-this/#findComment-71908 Share on other sites More sharing options...
March 9, 200421 yr comment_71918 That would not be a very efficient way to feed a dog: it would blow the food clear through undigested and you would assphyxiate the dog in the process. Link to comment https://www.classiczcars.com/forums/topic/10628-you-guys-gotta-hear-this/#findComment-71918 Share on other sites More sharing options...
March 9, 200421 yr comment_71922 Looks like your "seasoned mechs" had too many pre-conceptions to figure out what was really going on. Sometimes a "fresh" mind is better than an educated one... Dog Food....Did the engine rin a "Dog" before??? Do you fill theCAT-alytic convert with KAT-nip?? Link to comment https://www.classiczcars.com/forums/topic/10628-you-guys-gotta-hear-this/#findComment-71922 Share on other sites More sharing options...
March 9, 200421 yr comment_71948 How far did the dog food go? Maybe a good indication of compression?:tapemouth ROFL Link to comment https://www.classiczcars.com/forums/topic/10628-you-guys-gotta-hear-this/#findComment-71948 Share on other sites More sharing options...
March 9, 200421 yr Author comment_71973 Ahaha!Actually the car idles just fine but startup takes a fiew tries and sometimes when i gas it the revs actually go down and i can feel a huge power loss. I have a fiew ideas on whats causing this. Link to comment https://www.classiczcars.com/forums/topic/10628-you-guys-gotta-hear-this/#findComment-71973 Share on other sites More sharing options...
March 10, 200421 yr comment_71987 Something that causes a lot of problems and can be overlooked until many other things have been tried is the Vacuum Advance Mechanism in the distributor.Take the cap off the rotor, and using the hose that connects to the vacuum solenoid pot, suck on it to create a vacuum. You should see the insides of the distributor rotate a few degrees. When you release the vacuum, it should return to where it was before. Both of these travels should be SMOOTH and not jerky.Below the point plate there is a plastic plate that houses a few ball bearings. These are notorious for drying up and cracking, releasing the ball bearings and causing the vacuum advance mechanism to not work properly.2¢Enrique Link to comment https://www.classiczcars.com/forums/topic/10628-you-guys-gotta-hear-this/#findComment-71987 Share on other sites More sharing options...
March 10, 200421 yr comment_71989 If it take a few times to start up especially when it's cold you need to look into the thermotime switch/cold start valve combination. Link to comment https://www.classiczcars.com/forums/topic/10628-you-guys-gotta-hear-this/#findComment-71989 Share on other sites More sharing options...
March 10, 200421 yr comment_71998 Now Stephen, don't be mean! Enrique Link to comment https://www.classiczcars.com/forums/topic/10628-you-guys-gotta-hear-this/#findComment-71998 Share on other sites More sharing options...
