Got her started, have a question
Datsun-Fever
Just because you had to floor it to keep it running doesn't mean it was actually using a lot of gas. It could be that the timing is off, the carbs need adjusting, etc. If you don't already have one I'd suggest getting one of the aftermarket (Haynes, etc.) manuals.
When that car is right it need no gas to start. By 'more gas or less gas', I assume you mean that you are stepping on the gas pedal to start the car. It has a cold start circuit and the fuel pump is self priming.
My 79 ZX is not self priming..
That car starts up like a charm every time even if its been sitting for 3-4 weeks :D
Datsun Fever - your car could be low on compression.. hence why it takes a while to kick into action :)
I guess we haven't established what kind or year Z he owns.
Not in his initial post but after I mentioned that the carbs might need adjusting he replied that it's a fuel injected '79 280ZX at which point I basically turned clueless.
  • Who's Online   0 Members, 0 Anonymous, 433 Guests (See full list)
