Posted March 8, 200421 yr comment_71804 Hey guys, i finally started my car but it took alot of gas, i had to floor it a couple times. Is this because i had just replaced the bone-dry tank? thanks alot guys. Link to comment https://www.classiczcars.com/forums/topic/10629-got-her-started-have-a-question/ Share on other sites More sharing options...
March 8, 200421 yr comment_71805 Just because you had to floor it to keep it running doesn't mean it was actually using a lot of gas. It could be that the timing is off, the carbs need adjusting, etc. If you don't already have one I'd suggest getting one of the aftermarket (Haynes, etc.) manuals. Link to comment https://www.classiczcars.com/forums/topic/10629-got-her-started-have-a-question/#findComment-71805 Share on other sites More sharing options...
March 8, 200421 yr Author comment_71807 I actually just started it again, it needed less gas (this is a 79 280zx fuel injected) but it ran fine without throttle after it turned over. Link to comment https://www.classiczcars.com/forums/topic/10629-got-her-started-have-a-question/#findComment-71807 Share on other sites More sharing options...
March 9, 200421 yr comment_71824 When that car is right it need no gas to start. By 'more gas or less gas', I assume you mean that you are stepping on the gas pedal to start the car. It has a cold start circuit and the fuel pump is self priming. Link to comment https://www.classiczcars.com/forums/topic/10629-got-her-started-have-a-question/#findComment-71824 Share on other sites More sharing options...
March 9, 200421 yr comment_71838 Could it be that the car preferred a bit of gravy with it's Kibbles 'n Bits? ES Link to comment https://www.classiczcars.com/forums/topic/10629-got-her-started-have-a-question/#findComment-71838 Share on other sites More sharing options...
March 9, 200421 yr comment_71877 Quote Originally posted by sblake01 When that car is right it need no gas to start. By 'more gas or less gas', I assume you mean that you are stepping on the gas pedal to start the car. It has a cold start circuit and the fuel pump is self priming. My 79 ZX is not self priming.. That car starts up like a charm every time even if its been sitting for 3-4 weeks Datsun Fever - your car could be low on compression.. hence why it takes a while to kick into action Link to comment https://www.classiczcars.com/forums/topic/10629-got-her-started-have-a-question/#findComment-71877 Share on other sites More sharing options...
March 9, 200421 yr comment_71880 Quote Originally posted by 280zx Fever My 79 ZX is not self priming.. I guess we haven't established what kind or year Z he owns. Link to comment https://www.classiczcars.com/forums/topic/10629-got-her-started-have-a-question/#findComment-71880 Share on other sites More sharing options...
March 9, 200421 yr comment_71892 Quote Originally posted by sblake01 I guess we haven't established what kind or year Z he owns. Not in his initial post but after I mentioned that the carbs might need adjusting he replied that it's a fuel injected '79 280ZX at which point I basically turned clueless. Link to comment https://www.classiczcars.com/forums/topic/10629-got-her-started-have-a-question/#findComment-71892 Share on other sites More sharing options...
March 9, 200421 yr comment_71893 Quote Originally posted by 280zx Fever My 79 ZX is not self priming. Is your 79 ZX f.i. or carbs? I only ask because I don't know at which point the Aussie cars became f.i. Link to comment https://www.classiczcars.com/forums/topic/10629-got-her-started-have-a-question/#findComment-71893 Share on other sites More sharing options...
March 9, 200421 yr comment_71901 On my 83 Turbo, when I ran out of gas, trying to get it started again was a bear. It would crank until the battery was nearly flat before the system was fully primed again. Link to comment https://www.classiczcars.com/forums/topic/10629-got-her-started-have-a-question/#findComment-71901 Share on other sites More sharing options...
