Posted March 9, 200421 yr comment_71930 Would anyone know? we have a 260 with an engine (L28) from a ZX, with carbed head installed. The distributor has electronic spark instead of points. Where should the tach signal come from? I believe currently it is still connected to the negative post on the coil, yet the tach does not function. I personally have not been to the car yet to assist my friend. Any help would be greatly appreciated Link to comment https://www.classiczcars.com/forums/topic/10640-tach-signal/ Share on other sites More sharing options...
March 9, 200421 yr comment_71937 I haven't looked into on the on the 260, but on my 73 240Z the tach signal used a current loop and two wires in the area of the coil go to the tach. One of the wires by the coil goes to the tach, one comes back from the tach and is hooked to the coil. This might help you to figure it out. Link to comment https://www.classiczcars.com/forums/topic/10640-tach-signal/#findComment-71937 Share on other sites More sharing options...
March 9, 200421 yr Author comment_71938 Do you happen to know what wire connects where? I'm a little confused. They both would not be on the same post at the coil would they? Link to comment https://www.classiczcars.com/forums/topic/10640-tach-signal/#findComment-71938 Share on other sites More sharing options...
March 9, 200421 yr comment_71940 No. I don't recall. They were all there by the coil though. Both of those wires don't hook to the same terminal of the coil. One of the wires does not even connect to the coil. Link to comment https://www.classiczcars.com/forums/topic/10640-tach-signal/#findComment-71940 Share on other sites More sharing options...
March 9, 200421 yr comment_71942 The other end goes to the ballast resistor. Link to comment https://www.classiczcars.com/forums/topic/10640-tach-signal/#findComment-71942 Share on other sites More sharing options...
March 9, 200421 yr comment_71944 I was thinking the ballast resistor too, but it might not be there anymore with an electronic ignition. When I went electronic, I left the ballast resistor there just for the junction for the two wires. the other end of the ballast resistor wasn't connected to anything. Link to comment https://www.classiczcars.com/forums/topic/10640-tach-signal/#findComment-71944 Share on other sites More sharing options...
March 9, 200421 yr comment_71947 You're so right I forgot the part about the 280 engine...sorry:stupid: Link to comment https://www.classiczcars.com/forums/topic/10640-tach-signal/#findComment-71947 Share on other sites More sharing options...
March 9, 200421 yr Author comment_71949 So was the ballest resistor just left there to connect the 2 wires together? Link to comment https://www.classiczcars.com/forums/topic/10640-tach-signal/#findComment-71949 Share on other sites More sharing options...
March 9, 200421 yr comment_71950 On mine, yes. Can guarantee this is what you have. I am thinking the ignition power wire went to a connector on the ballast resistor, one tach wire went to the same connector, the other tach wire went to the positive side of the coil. There was no connection to the other side of the ballast resistor.So the coil power path looks like battery->ign switch->ballast resistor->tach->coil. Lots of stuff (too much stuff) between the battery and the coil. Link to comment https://www.classiczcars.com/forums/topic/10640-tach-signal/#findComment-71950 Share on other sites More sharing options...
March 9, 200421 yr Author comment_71951 Thanks for the info guys-really appreciate it! Link to comment https://www.classiczcars.com/forums/topic/10640-tach-signal/#findComment-71951 Share on other sites More sharing options...
