Recommendations on replacement ignition
lvmy240z
Alot of guys use the PERTRONIX unit. It installs in your stock distributor and is a magnetic trigger type unit. I went for the Mallory Unilite setup. You may want to search the archives for details and or reviews.
I know the Pertronix system won't handle the fuel management, but is there something that will work ALONG WITH the Pertronix system and the stock AFM on a 280Z? May a Pertronix fuel management computer? I think it would be in my best interest to upgrade/replace everything eventually.
thx.
Quick, easy, very cheap and bolts right in easily.
If you know what your doing you could be running in less then 20 minutes.
Also, you can get a newly remaned distributor for the 79-80 ZX from advanced auto for about 79 dollars with a lifetime gaurantee.
Price may have went up though since last time I did that it was about 3 years ago.
  • Who's Online   2 Members, 0 Anonymous, 393 Guests (See full list)
