Posted March 16, 200421 yr comment_72884 I am in need of some oversized piston pins. I have a set of oversized pistons but the pins look to have been beat out with a hammer. I can have the pin holes honed out but then the piston pin is too small. Has anyone out there run into a similiar problem? Any help? Thanks Link to comment https://www.classiczcars.com/forums/topic/10763-oversized-piston-pins/ Share on other sites More sharing options...
March 16, 200421 yr comment_72890 Why would one want to install a set of abused pistons in an engine? Doesn't the fact, that the pistons are beat up indicate to you anything? Link to comment https://www.classiczcars.com/forums/topic/10763-oversized-piston-pins/#findComment-72890 Share on other sites More sharing options...
March 16, 200421 yr comment_72901 If someone took a hammer to get the pins out I would bet money that the pistons and the rods are dammaged. Link to comment https://www.classiczcars.com/forums/topic/10763-oversized-piston-pins/#findComment-72901 Share on other sites More sharing options...
