Z starting problems
ALT_255
well i finaly got the injector hoses replaced... all 12 of them... that was a serious pain.
now the car wont start, will crank over but dies right away does not respond if i give it gas. i understand car problems are hard to fix w. out checking out the car but can any one give me some ideas as to where to start? maby a bunch of stuff to rule out?
any and all help welcomed
-Jon
p.s. its a 77 280z fuel injected
Update
i messed around with the afm and now the car will start and idle w. spray start. if you hit the gas it will rev but after a min or so starts to bog out and dies, hitting the gas does not help at all.
fuel problem right? i checked the fuel pump, its pumping
any ideas?
Could be fuel filter, gas tank, or anywhere inbetween. I would start with a fresh fuel filter to rule it out and run the fuel pressure test that is in the fsm if the problem still exixts. How long did the car sit before you purchased it?
i replaced the fuel filter, i can now get started w. starter fluid and it will run for aprox. 2 min and then it starts to bog down.
i was trying to rev it up to clear out anything stuck in the injectors
and it bogged down real bad and the engine started to smoke from the area around the injectors?????
bad/clogged injectors?
thanks for the help so far sblake and frank
went and checked it organ, their right... that would be a funny way to fix the car...
anyways does anyone in IL know of a shop that can clean injectors? i think they are working fine, i did the test w. the long screwdriver and they clicked ok..
anything else i should try?
p.s. the car has ben sitting for about a year and the lines going into the injectors were completly mealted, like they were disolving in my hands when i got them off
Originally posted by ALT_255
. . . the car has ben sitting for about a year . . .
The reason I asked about that is when I bought my 78 in 1997 it has been sitting for quite a while and the gas tank had to be replaced because of all the sediment that had developed over that period of time.
i got a fuel pressure gauge and put it on, and started her up.
i have found that if i stick a wrench up the afm to hold the flap open untill the preasure gets to ~36 psi the car starts right up and will idle for a while, ~2 min, while it is idling i can rev the car up and everything, but after a little while it starts to bog down and smoke comes from down by the headers...
im going to fill the tank all the way up and see if that helps the pump and if noti guess i will replace the fuel pump and see where that puts me...
is this a good course of action? other things to try?
  • Who's Online   1 Member, 0 Anonymous, 718 Guests (See full list)
