Rear caliper mounting brackets
240ZX
Hey guys,
A couple of days ago, there was a post that discussed the rear disc brake conversion on early Z's and some of the folks were interested in what to use for the rear caliper mounting bracket. Well, I looked through my files last night and here is the info:
When installing 82 - 83 280ZX rear calipers on the early Z cars, use the following p/n DAT 4415504S10 ADAPTOR C (2req)
These are caliper mounting brackets from 81 - 84 Maxima front wheel drive cars and they are the ticket, as opposed to fabricating your own brackets from raw stock. Yes, a factory Nissan (Datsun) part that bolts right upto your early Z.
Lance,
Looks like the price hasn't gone up! Got mine from Courtesy Nissan about two years ago. I just think its so cool that so many parts interchange between models.............thrifty engineering I suppose!!!
Chris,
Without accessing my files at home.......As I recall there are two different rear discs to choose from on the 280ZX's. Basically one has more offset than the other. The want to use the one with the least amount of offset. I'll look for details tonight when I get home and post the info tomorrow......unless one of members can help us out here.
Chris,
Another tidbit of info that may be of use to you. Of course, go with S.S. flex hoses on all four corners and I recommend the AXXIS Metal Master pads (manf'd in Australia) as well. They work great and shead minimal brake dust, if any. These pads are rotor friendly and claim to last up to four times longer than standard issue pads. So far, I am a believer!!!
For my conversion I used 300zx front rotors turned down about .2" in diameter with 81 zx front calipers, a spacer was needed between the caliper and the mount to center it over the rotor.
Rears used 83 280zx turbo calipers and non turbo rotors, no spacers etc needed it all just bolted on.
To complete the conversion I used the MC and proporsioning valve from the 81 zx.
I got the best prices on the rotors at rockauto.com, American made and real nice. Whole conversion cost me around $250 plus what I took off of the 81 parts car.
  • Who's Online   1 Member, 0 Anonymous, 580 Guests (See full list)
