Posted March 15, 200223 yr comment_4039 Hey guys,Anybody know the standard master cylinder bore size that was on '73 240s?R Link to comment https://www.classiczcars.com/forums/topic/1089-master-cylinder-bore/ Share on other sites More sharing options...
March 15, 200223 yr comment_4040 I believe they are 7/8 inch. Link to comment https://www.classiczcars.com/forums/topic/1089-master-cylinder-bore/#findComment-4040 Share on other sites More sharing options...
March 16, 200223 yr comment_4054 Yes it is 7/8ths and it is probably stamped on the side of the master cylinder casting. The stamp should be on drivers left near the base of the master cylinder where it mounts to the vacuum booster. So if you open the inspection lid on the drivers side you should be able to see it. Might need a mirror and a flashlight if your eyes are a little worn but the numbers are fairly large.Have fun! Link to comment https://www.classiczcars.com/forums/topic/1089-master-cylinder-bore/#findComment-4054 Share on other sites More sharing options...
March 16, 200223 yr Author comment_4055 Thanks guys you were spot on : ) Link to comment https://www.classiczcars.com/forums/topic/1089-master-cylinder-bore/#findComment-4055 Share on other sites More sharing options...
