Mudpi Posted March 15, 2002 Share #1 Posted March 15, 2002 Hey guys,Anybody know the standard master cylinder bore size that was on '73 240s?R Link to comment Share on other sites More sharing options...
2ManyZs Posted March 15, 2002 Share #2 Posted March 15, 2002 I believe they are 7/8 inch. Link to comment Share on other sites More sharing options...
Royce Posted March 16, 2002 Share #3 Posted March 16, 2002 Yes it is 7/8ths and it is probably stamped on the side of the master cylinder casting. The stamp should be on drivers left near the base of the master cylinder where it mounts to the vacuum booster. So if you open the inspection lid on the drivers side you should be able to see it. Might need a mirror and a flashlight if your eyes are a little worn but the numbers are fairly large.Have fun! Link to comment Share on other sites More sharing options...
Mudpi Posted March 16, 2002 Author Share #4 Posted March 16, 2002 Thanks guys you were spot on : ) Link to comment Share on other sites More sharing options...
