Identify this part
NH-75-Z
Am planning on replacing the fusible links with a gold plated
fuse block, on my 75-280, California model Z.
I only have 1 fusible link box, located on the relay bracket.
It contains 2 links, 1 green labeled Ign, and 1 black labeled
batt.
Underneath this box, is a metal box, 2" x 2" x 6" and it
contains a copper strip, shaped like a "m", and 2 glass
fuses. 2 large gauge wires ( 8ga maybe ) one white and
one white/red connect to the large metal strip, and 2
light gauge wires, same colors, connect to the 2 glass
fuses.
My question is : is this unit the fuse for the charging
system ? Thus can be replace by 60 amp fuse.
FSM shows 2 normal fusible link boxes, but this metal
box appears original,connects to harness ,etc.
Voltage regulator is mounted underneath this relay
bracket, and car has no A/C, so its not some relay.
