kyteler Posted March 26, 2004 Share #1 Posted March 26, 2004 Hey there Guys,I know this is in the 240K forum but it's irrelevant I imagine...I finally got the tranny swap all sorted and it's all in and bolted up, the shifter is in perfect position however... I can't find any info on wiring in regards to the starter.I searched the forums and nothing addressed the problem other than a link to zhome which partially helped out in possibly clarifying what I thought the problem was.On an auto there's a mechanism to stop the car starting whilst it's in gear.How do I sort out the wiring now that there's no stupid 3 speed auto on there anymore..My poor car, she's sitting on ramps and just needs to start. Link to comment Share on other sites More sharing options...
2ManyZs Posted March 26, 2004 Share #2 Posted March 26, 2004 I guess the biggest question is where the neutral safety switch is. Is it on the old auto shift linkage or is it somewhere "invisible"..... It ought to be just a simple two wire switch that you could just unhook the wires and connect the two of them together to bypass the switch.... Link to comment Share on other sites More sharing options...
kyteler Posted March 26, 2004 Author Share #3 Posted March 26, 2004 OK, well.. with Lachlan's help (Alfadog) I got a wiring diargram.. which made sense and seems to do at least something.. but not enough. At least now the starter solenoid is clicking... but it's still baffling me. So I got frustrated and shorted the start motor to bring her to life.. and took her for a run.. WEEEEEEEEEEEEEEEEEE. Now tomorrow I've got to try figure out what's going on :mad: Link to comment Share on other sites More sharing options...
kyteler Posted March 26, 2004 Author Share #4 Posted March 26, 2004 Originally posted by 2ManyZs I guess the biggest question is where the neutral safety switch is. Is it on the old auto shift linkage or is it somewhere "invisible"..... It ought to be just a simple two wire switch that you could just unhook the wires and connect the two of them together to bypass the switch.... I think the switch itself is located inside the transmission.. however, I tried several combinations of wire connectings from the tranny section of loom to no avail.. I was getting nothing. After receiving the diagram from Alfadog I clarified what each wire actually meant and tried again, unfortunately.. all it resulted in was the click I mentioned in the last post.. Perhaps there's just something wrong with that starter motor/solenoid.. even though it's clicking and it runs fine when you short it between the power and ignition switch. I'll try the other starter that was on the auto tomorrow.. I hope that's all it is.. because being able to start the car without a screwdriver across terminals would be good I also have a speedo problem.. Im probably going to have to run the cog that came in the 5speed because when I changed to the auto one, the cog body must be the wrong offset because it doesnt spin the cog at all, so it mustn't even be touching inside. It's great to actually have a 5speed though I'm excited and I've only driven it for about 2 minutes and that was several hours ago! Link to comment Share on other sites More sharing options...
ChrisA Posted March 26, 2004 Share #5 Posted March 26, 2004 Hey Michael, I think if the auto tranny was the Jatco unit, the switch is bolted to the right side. Maybe if you took the switch off the tranny and left it plugged in to the harness and rotated it as if it were in Park or Neutral then maybe the car would start. I had a Silvia(200SX) and the switch went bad. I thought there were 3 wires coming out of it. Its been a long time since I had that car though. Maybe you could just tie the switch up somewhere and leave it. If I remember correctly, its a rather odd looking kinda round switch. Hope this helps some. Link to comment Share on other sites More sharing options...
HKSZ Posted March 26, 2004 Share #6 Posted March 26, 2004 I know in a zed there are 4 wires with bullit connectors running to the auto, you simply reconnect them male to male and female to female.Perhaps without the auto now the starter itsnt earthing properly, you may need to run another earth leed from strut top to enginesteve Link to comment Share on other sites More sharing options...
St.stephen Posted March 26, 2004 Share #7 Posted March 26, 2004 I am completely unfamiliar with 240k's and could be totally wrong.... however wouldn;t the auto and manual starters be differant due to the ring gear on the flywheel and or flexplate? Link to comment Share on other sites More sharing options...
kyteler Posted March 26, 2004 Author Share #8 Posted March 26, 2004 Just to let you guys know I am running (well attempting to) a manual starter, I'm going to try the old auto starter today once I get off my arse. Link to comment Share on other sites More sharing options...
kyteler Posted March 27, 2004 Author Share #9 Posted March 27, 2004 Thanks for the suggestions and help guys, it's much appreciated. It turns out it was just something with the other starter motor, so I'll have to get it sorted. For the moment though.. the old Auto starter is on there and she's running sweeeeeeeeeeeeet. Couldnt be more happy with her.. speedo is a bit out, but I used my brother driving 50 to figure out exactly what was going on speed wise and I'm pretty safe there now too. I'll still try and get the proper cog sorted.. eventually For the moment I'm just happy she's all going! WOOHOO! went for a trip to the local autoparts accessory store.. ending up driving several other places back and forth across town for no other reason than to drive her Link to comment Share on other sites More sharing options...
Razor Posted March 28, 2004 Share #10 Posted March 28, 2004 Good work MichaelI wish you could've taken some photos of your swap it might be very helpful when I do mine.anyway have fun with your 5 speed! Link to comment Share on other sites More sharing options...
kyteler Posted March 31, 2004 Author Share #11 Posted March 31, 2004 At some stage I'll write the process down to make it easier for others, it's fairly simple.Just a little time consuming if you dont make sure you have the right tools. :stupid: Like I didn't.Note: Make sure you actually DO have a 12mm ring spanner and dont assume you do have one, cause that driveshaft isnt going anywhere without one.This would have been a helpful artical for me... if I had of found it beforehand. But I didnt til afterwards.So for you guys;http://www.zhome.com/ZCMnL/tech/auto2man-gearbox.html A few things on it I didnt worry about or I did it slightly differently but I'll do a write up with pictures or something later on. Link to comment Share on other sites More sharing options...
Razor Posted April 2, 2004 Share #12 Posted April 2, 2004 I read that article you posted and I think I'll leave it to the mechanics to do the swap.... :stupid: I wish I can do it myself as I would like to learn but still need someones supervision or who knows a little bit to help me.I'm asking this friends cousin to help me with it... just few more beers to go.... Link to comment Share on other sites More sharing options...
