Posted March 30, 200421 yr comment_74824 Hi All, finally the yellow 240Z hits the dyno... puts out 366.7 RWHP on a Dyno Dynamics chassis dyno on Shootout mode - this is at a conservative 15psi (just over 1 bar) setting because the engine is ALL internally stock standard ! tuning abandoned due to standard R32 GTR clutch slipping so my new HKS twin plate one is going in tomorrow and back on the rollers for all Perth crowd, car will be out for the 1st time for the national event, Drag Combat on April the 10th if you want to catch it in action. Take care, Cuong Link to comment https://www.classiczcars.com/forums/topic/11005-rb26-240z-hits-the-dyno/ Share on other sites More sharing options...
March 30, 200421 yr comment_74829 HEHE cant wait to see the results after the new clutch is in. Can you post the dyno sheet, Id love to see the torque curve and a/f readings.On another note, Im sure the stock bottom end on that RB motor can handle more the 15psi. My L28ET handles that much quite easily.Turn it up a bit:devious: Link to comment https://www.classiczcars.com/forums/topic/11005-rb26-240z-hits-the-dyno/#findComment-74829 Share on other sites More sharing options...
March 30, 200421 yr comment_74874 Yup, RB internals are fairly tough.My RB30 is on its way home too cuong and my engine bay is all painted up ready to accept it.Will be intersting to compare notes once running. Link to comment https://www.classiczcars.com/forums/topic/11005-rb26-240z-hits-the-dyno/#findComment-74874 Share on other sites More sharing options...
