Posted April 4, 200421 yr comment_75424 Ok heres the problem: When i touch the exhaust tip the whole thing started moving, and it wobbled for a while, looking under the car shows that it is attached to nothing, it goes straight from the header to the end. I cant see any places where the thing might have mounted. So can someone give me some advisory on what to do? Thanks alot. Link to comment https://www.classiczcars.com/forums/topic/11083-exhaust-pipe-problems/ Share on other sites More sharing options...
April 4, 200421 yr comment_75426 And mount it up to the stock locations. Should be 2 or 3, huh cant remember.In any event if you go to your local parts store they should have a diagram of it in the muffler book, that is if they are not to lazy to look for you. Link to comment https://www.classiczcars.com/forums/topic/11083-exhaust-pipe-problems/#findComment-75426 Share on other sites More sharing options...
April 4, 200421 yr comment_75430 There are 3 exaust mounts. They look like 1 inch thick and 3 or 4 inch long pieces of leather (there not leather they just look sort of like leather). You should be able to get them at a good auto parts store. Actually they may still be there under your car. they are held on by bolts and over 30 years the bolts can rust off or tear off. Its easy to fix, you just need some jack stands and some dirty cloths. Enjoy, Matt- Link to comment https://www.classiczcars.com/forums/topic/11083-exhaust-pipe-problems/#findComment-75430 Share on other sites More sharing options...
April 4, 200421 yr comment_75431 dont drive that way for long. the extra stress of the pipe can crack the manifold. then you have a mess. Link to comment https://www.classiczcars.com/forums/topic/11083-exhaust-pipe-problems/#findComment-75431 Share on other sites More sharing options...
April 4, 200421 yr comment_75447 I never knew pie could cause so much stressROFL Hell I even like pie:devious: Sorry Bill but I just couldnt resistLOL Link to comment https://www.classiczcars.com/forums/topic/11083-exhaust-pipe-problems/#findComment-75447 Share on other sites More sharing options...
April 4, 200421 yr comment_75448 Damn I love Pie! When I don't get enough I deffinatly get STRESSED! Link to comment https://www.classiczcars.com/forums/topic/11083-exhaust-pipe-problems/#findComment-75448 Share on other sites More sharing options...
April 4, 200421 yr comment_75480 ha ha ha very funnyROFL Link to comment https://www.classiczcars.com/forums/topic/11083-exhaust-pipe-problems/#findComment-75480 Share on other sites More sharing options...
