Ok I have a 1973 with stock suspension, and it so needs a complete upgrade. I am all over the road with bumps (exaggerating a little bit). So I want to put in new struts spring and Bushings. Is there anything else I should be doing? and what products would be good to get. I want to get some decent quality stuff but money is an object. So I know of Tokico and KYB but I would really like your guys input on what is good for a good price. I don’t really need adjustable unless it really makes a difference. So if you have any input post it up thanks alot.
Paul
You can try Nissan at this site:
http://www.courtesyparts.com/energysuspension/oldzcar.html
or try this one also:
http://zbyter.home.attbi.com/
My Z has Tokico non-ajustable shock and lower springs, but i haven't ride in the car yet because it is still in storage. I'm waiting for the snow to go awaaaaaaaaaaaay... Can't help you to give a feedback from my ride...:(
Try www.shox.com They have the lowest prices I could find for the suspension stuff. I also tried stricklyz, motorsports industries, victoria british and www.nismoparts.com but shox.com was the lowest. Do make some calls because prices where all over the place. AS an example, I saw Eibach springs anywhere from $280.00 down to $209.00 for a complete set.
I went with the Tokiko non-adjustable strut inserts - they were the most reasonably priced back when I was looking around. I also went with Suspension Techniques springs - they supposedly only lower the car about 1.5 inches. After 30 years, the old, tired original springs were already sagging the 1.5 inches, so I can't tell any difference between the before and the after look.
I also replaced all of the old rubber bushings, including the steering rubber, with polyurethane while doing the suspension project. The handling improvement was significant.
Good luck with your project.
