Ok, this is the last dumb question I ask ( I hope). Every article I've read on the R200 swap into a 71 Z say's to get the r200 HALF SHAFTS also.Motorsport Auto tells me that the R180 halfshafts will work fine. Has anybody used the R180 halfshafts on the r200 swap?Will it work?
https://www.classiczcars.com/forums/topic/11133-r200-swap/
I used R180 shafts with an R200, worked fine. apparentley the R200 shafts are shorter to compensate for the wider diff, though with the range of movement the R180 shafts have inout wise is enough to work with the R200.
i could be wrong but the R200 shafts i think have finer splines that are less prone to breakage? can someone confirm this?
https://www.classiczcars.com/forums/topic/11133-r200-swap/#findComment-75812
  • 3 weeks later...
yes all is true the 200 half shafts have a finer spline but i seriosly doubt you will break the r180 ones and origanal r180 half shaft will not fit an r200 because they way they bolt to the diff is different 240 r180 has a plug in style half shaft just like a p510 r160 while the r200 has a flange where the half shafts are bolted on.....hope that helps
https://www.classiczcars.com/forums/topic/11133-r200-swap/#findComment-80153
  • 3 weeks later...
Just a heads up: http://www.betamotorsports.com/benchracing/index.html
Look at the R200 handling issues.
I used to think the halfshafts were different on the R200s. Not so sure anymore after measuring mine.
Also the 200 side input shafts are held in with a circlip, so you can pop them out of the side of the diff with a prybar. Not sure, but I thought it was the 180's that bolted in.
https://www.classiczcars.com/forums/topic/11133-r200-swap/#findComment-83117
