Howdy!
I've just become the proud owner of a second rust bucket of the z car variety. ;)
This one is the 2+2 that sjcurtis had seen on the RAAF base here. A big thanks to steve for letting me know about it. :)
Anyhow, while it looks like a total dunger, it really isn't all that bad. The interior is a complete mess, but other than a cracked dash and torn seat covering it's actually pretty good. All the switch gear in this thing feels like new. Let me tell you it's quite a difference from mine! Body wise it has some small crash damage to the left door and fender and some rust, but nothing too bad.
Anyhow, pretty much everything is for sale other than gearbox (manual) and a few interior bits and pieces. I might keep the motor too unless someone really wants it. Oh it has two sets of carbs too, the original flat tops that were in the boot, and some round tops that were on the motor. They aren't 240Z round tops though! I'll have to pull them off and work out what exactly they are. I'll be selling it a cheap too.
PM me if you want anything.
http://users.bigpond.net.au/oceanz/z/DCP_6936.jpg
billramsey2002: PM sent.
240Zdragon72: The guy couldn't find the ignition key for it, but said he'll keep looking. I've just drilled out the bolts so I can still move it around in the mean time. I'll post up if he finds it.
gav: The diamond vinyl on the trans tunnel? Yep, still there and appears to be completely intact, although a bit dirty. The whole interior is a complete mess. It's been sitting like this for three years.
Most of the interior appears to be ok, other than the vinyl on the front seats being ripped.
http://users.bigpond.net.au/oceanz/z/DCP_6947.jpg
http://users.bigpond.net.au/oceanz/z/DCP_6948.jpg
http://users.bigpond.net.au/oceanz/z/DCP_6949.jpg
Sorry but it's the wrong stiching pattern. I'll try show you what I'm after, it's much nicer looking in my opinion i'll let you know if i might be after anything else though.
Gav
http://www.classiczcars.com/forums/attachment.php?s=&postid=54629
Pic courtesy of Kats this is the pattern i'm after unripped.
I think maybe in the 260z especially later years they changed the pattern to the one you showed me.
Yeah must have changed for the 260.. interesting, I agree with you Gavin the 240's stitching is much nicer. OK, starting to miss my Z now...................
*remembering fondly the days when I used to get down there and clean out the dirt from the vinyl with a toothbrush*
Justin, I'll have the front struts, if they are the later 260 type. I can get the strut tube OD measurement if you want it, early 260's had the slightly smaller OD strut tube 240 size struts. I'd just want the bare struts without the springs.
Alfadog: :D
260DET: What sort of time frame do you need them in? It's just that once they are out the car wont be going anywhere....and I still need to be able to move it around for now.I suppose I can always dodgy up a solid bar in there instead(?).
Guest
Reply to this topic...
