Posted April 12, 200420 yr comment_76706 i am doing an oil change on my 71 z. i took off the oil cap, and the filter and waited for the oil to come out and nothing happend. i checked the dip stick and it said there was lots of oil in there. any reason why it does not come out? i tried turning the motor over and it did nothing. any ideas? i dont want top put more oil in there if it wont come out. Link to comment https://www.classiczcars.com/forums/topic/11223-oil-that-does-not-come-out/ Share on other sites More sharing options...
April 12, 200420 yr Author comment_76707 :stupid: Link to comment https://www.classiczcars.com/forums/topic/11223-oil-that-does-not-come-out/#findComment-76707 Share on other sites More sharing options...
April 12, 200420 yr comment_76719 Originally posted by echocluster :stupid: Link to comment https://www.classiczcars.com/forums/topic/11223-oil-that-does-not-come-out/#findComment-76719 Share on other sites More sharing options...
April 12, 200420 yr comment_76723 C'mon, explain yourself! I need a laugh. Link to comment https://www.classiczcars.com/forums/topic/11223-oil-that-does-not-come-out/#findComment-76723 Share on other sites More sharing options...
April 12, 200420 yr comment_76726 Originally posted by tanny C'mon, explain yourself! I need a laugh. no mention of removing the oil pan plug? Link to comment https://www.classiczcars.com/forums/topic/11223-oil-that-does-not-come-out/#findComment-76726 Share on other sites More sharing options...
April 12, 200420 yr Author comment_76734 i had a brain freeze and thought that the oil would come out when a took off the oil filter. i did have a thought isnt there something else i should be doing? na i said to myself.so now i have another problem i changed the fuel filter and now no fuel comes out. i there is nothing coming out of the hose. is the fuel pump messed up somehow? Link to comment https://www.classiczcars.com/forums/topic/11223-oil-that-does-not-come-out/#findComment-76734 Share on other sites More sharing options...
April 12, 200420 yr Author comment_76742 can you feel suction on the line that goes the filter when you turn the car over? Link to comment https://www.classiczcars.com/forums/topic/11223-oil-that-does-not-come-out/#findComment-76742 Share on other sites More sharing options...
April 12, 200420 yr comment_76743 There is no fuel pressure unless the engine is running. Just replace the filter, and tighten the hose clamps. Where the filter is located, the pump will "suck" fuel when the engine is running. Link to comment https://www.classiczcars.com/forums/topic/11223-oil-that-does-not-come-out/#findComment-76743 Share on other sites More sharing options...
April 12, 200420 yr Author comment_76745 why is the web site so slow today? anyway i did all the things you said and i just got it running . it sounds terrible . i might have got the plug wires messed up does any one know which way they should go? or any thing else that might be the problem? Link to comment https://www.classiczcars.com/forums/topic/11223-oil-that-does-not-come-out/#findComment-76745 Share on other sites More sharing options...
April 12, 200420 yr comment_76747 See attachment. #1 Cylinder is the one closest to the radiator, #6 is the one closest to the battery. Link to comment https://www.classiczcars.com/forums/topic/11223-oil-that-does-not-come-out/#findComment-76747 Share on other sites More sharing options...
April 12, 200420 yr comment_76751 Echo , I have a really good piece of advise. Buy a repair manual ! The best is a Nissan shop manual but they are not cheep. You can find Chilton or Haynes on e-bay for about $9.00 . In there you will find the information you need. Fireing order how to adjust things and make repairs. To have your Z run in good order and keep it that way, there is basic knowledge needed that is specific to Z cars. Some times you can find these manuals in the used book stores. Here on this site is a good place to get information , but for reference get the books. Check out the Tec. pages there is a ton of good info there. Link to comment https://www.classiczcars.com/forums/topic/11223-oil-that-does-not-come-out/#findComment-76751 Share on other sites More sharing options...
April 12, 200420 yr comment_76752 Hey that sounds like somthing i would do . Yeah if those plug wires arnt right it will run terrible. Link to comment https://www.classiczcars.com/forums/topic/11223-oil-that-does-not-come-out/#findComment-76752 Share on other sites More sharing options...
