Recently Browsing 0
Ok, I came across a fix today. During the day our site was slowing down to a screeching halt and I originally thought more RAM would fix the problem.
After digging into my configuration a little more I discovered that our backups are HUGE! Original backups used to take us just a few minutes, but, now they are taking longer due to the sheer size of our database, graphics, and overall system. This is very common for an active site like ours.
Anyway, because of this increase, my backups were beginning to overlap in time. Thus, causing a series of backups to run at the same time. Two and three backups were eventually running simultaneously causing the site to suffer for resources (memory, cpu, etc).
It also doesn't help that I accidentially scheduled the backups to start at 11am! I picked the wrong side of the clock because I should have picked 23 (or 11pm).
The fix was to allow enough time to pass between backups and also start the whole process at 1am (instead of 11am). All of these times are US Pacific Time (-8GMT).
The site should no longer experience slow-downs in the middle of the day.
Yes, RAM would have helped this problem. But, it was an unnecessary expense to cover up a problem that would have manifested itself after another year or so anyway.
Over.
https://www.classiczcars.com/forums/topic/11255-site-slowdown-fix-found/Share on other sites
