Posted April 16, 200421 yr comment_77424 Anybody have problems with carb clearance on a MSA header ?I bought a MSA 3-2 coated header for my 260 and have since sent it back to them. I believe it's badly manufactured since on bolting it up the carbs(early SU's) are essentially touching the second pipe. There's plenty of room for routing it so there'd be much more clearance, like the other five pipes. MSA says it's bolted up on their showroom floor and has an 1/8" clearance with same early carbs and E88 head. I've never dealt with a header before, but considering the heat issues with the car I think I'd be insane to have so little space there. Has anybody run into this issue before with this header ? Has anybody seen that little clearance before and not had problems ? Any suggestions for alternatives ?Thanks,jerry5453 Link to comment https://www.classiczcars.com/forums/topic/11303-msa-header-problem/ Share on other sites More sharing options...
April 16, 200421 yr comment_77438 I think this has been run into previously, try searching. Link to comment https://www.classiczcars.com/forums/topic/11303-msa-header-problem/#findComment-77438 Share on other sites More sharing options...
April 16, 200421 yr comment_77462 Didnt have a problem with fitment though, and still had enough room for the heat shield.Personally I like the 6 into 1 myself. Link to comment https://www.classiczcars.com/forums/topic/11303-msa-header-problem/#findComment-77462 Share on other sites More sharing options...
April 22, 200421 yr Author comment_78211 Thanks for the replys gema & ZmeFly.I did search for like problems and foundbottom end interference problems but no top end. But, most of the headers seem to be 6 to 1 and not the 3 to 2.So my choices are 1) Get money back & buy a different header; 2) Get that header back from MS and see if it makes the heat problem worse; 3) Replace my stock manifold(cracked) & downpipe (warped flange).hmmmmmmmmmmjerry5453 Link to comment https://www.classiczcars.com/forums/topic/11303-msa-header-problem/#findComment-78211 Share on other sites More sharing options...
April 22, 200421 yr comment_78219 Just out of curiosity, do you have the phenolic insulator spacers on the intake manifold? Link to comment https://www.classiczcars.com/forums/topic/11303-msa-header-problem/#findComment-78219 Share on other sites More sharing options...
