Posted April 17, 200421 yr comment_77584 Ok, 73 240Z, new clutch MC and slave, was able to bleed them fine, the problem is I have the adjustment out to the last thread and the clutch is still at the floor! Still not blead? Everything works fine just I don't like the clutch engaging a 1/4" off of the floor!Looking for suggestions! Link to comment https://www.classiczcars.com/forums/topic/11313-not-enough-clutch-adjustment/ Share on other sites More sharing options...
April 17, 200421 yr comment_77591 Could be that it has air trapped in the MC, you shouldn't have to use the pedal adjustment at all when you just change the MC and SC. Unless it was way out of adjustment to begin with. Link to comment https://www.classiczcars.com/forums/topic/11313-not-enough-clutch-adjustment/#findComment-77591 Share on other sites More sharing options...
April 17, 200421 yr Author comment_77594 Since the clutch MC dosen't have a bleeder any suggestions as to make sure it is bled?? just loosen the fitting and pump away??? Link to comment https://www.classiczcars.com/forums/topic/11313-not-enough-clutch-adjustment/#findComment-77594 Share on other sites More sharing options...
April 17, 200421 yr comment_77596 If you open the bleeder on the slave cylinder it will bleed by gravity. What you want to do, is close the bleeder on the slave enough that it won't bleed by gravity, but will bleed if you depress the clutch pedal. The little bit of back pressure you create will often times force the air out of the MC that otherwise would stay there if you do it by gravity.That's the way I've always done it and it seems to work. Link to comment https://www.classiczcars.com/forums/topic/11313-not-enough-clutch-adjustment/#findComment-77596 Share on other sites More sharing options...
April 18, 200421 yr Author comment_77604 OK I'll try that, I did a gravity bleed for the most part when I put it in with a few pumps. Link to comment https://www.classiczcars.com/forums/topic/11313-not-enough-clutch-adjustment/#findComment-77604 Share on other sites More sharing options...
April 4, 200520 yr comment_119464 Was that the fix? Link to comment https://www.classiczcars.com/forums/topic/11313-not-enough-clutch-adjustment/#findComment-119464 Share on other sites More sharing options...
April 5, 200520 yr Author comment_119525 byunique said: Was that the fix?I'm afraid that it got put in the "I'll look at this later" catagory as body work and paint are in process. Link to comment https://www.classiczcars.com/forums/topic/11313-not-enough-clutch-adjustment/#findComment-119525 Share on other sites More sharing options...
April 5, 200520 yr comment_119535 Also, check the pedal/master cylinder pushrod connection. Pull the pin out and inspect. you will be amazed on how a little bit of wear on the pin and pushrod yoke can make a huge difference in clutch action. Link to comment https://www.classiczcars.com/forums/topic/11313-not-enough-clutch-adjustment/#findComment-119535 Share on other sites More sharing options...
April 5, 200520 yr comment_119545 Victor Laury said: Also, check the pedal/master cylinder pushrod connection. Pull the pin out and inspect. you will be amazed on how a little bit of wear on the pin and pushrod yoke can make a huge difference in clutch action......and the chutch pedal arm itself. In my experience the pin and pedal arm will wear the most and can become quite deformed. Link to comment https://www.classiczcars.com/forums/topic/11313-not-enough-clutch-adjustment/#findComment-119545 Share on other sites More sharing options...
April 5, 200520 yr comment_119561 I've got a similar situation (me thinks): Clutch grabs strong but the pedal is damned near on the floor before fully engaged. I tried poking my head up under the dash to inspect the pedal pivot point/hole for wear but I cant see it (I am DEFINITELY not as limber as I used to be). Question: Are the pedals grouped as an assembly, and/or does the pedal need to be pulled in order to inspect this? Or do I just need to get my son (infinitely more limber than me) to crawl under there to see it properly? Link to comment https://www.classiczcars.com/forums/topic/11313-not-enough-clutch-adjustment/#findComment-119561 Share on other sites More sharing options...
April 5, 200520 yr Author comment_119571 Son time to see if things are worn you will have to pull the pin that drives the clutch MC then I think that you can get the pedal out, been a while since I fit myself down in there, it is also a lot easier with the seat out of the car. Link to comment https://www.classiczcars.com/forums/topic/11313-not-enough-clutch-adjustment/#findComment-119571 Share on other sites More sharing options...
April 5, 200520 yr comment_119576 Gawd, this brings back some memories I'd rather forget! It will help if you can employ a contortionist or a midget, to crawl up under the dash for you. Space is certainly limited!!! Link to comment https://www.classiczcars.com/forums/topic/11313-not-enough-clutch-adjustment/#findComment-119576 Share on other sites More sharing options...
