July 3, 200519 yr comment_129430 Problem solved. Link to comment https://www.classiczcars.com/forums/topic/11335-tie-rod-help-needed-quick-before-school-starts/?&page=3#findComment-129430 Share on other sites More sharing options...
June 23, 200915 yr comment_287640 Been looking through various threads concerning the lock nut on the tie rod because I want to get a replacement left hand thread nut for the drivers side. The one that was on there got chewed up a bit trying to get it lose (It will still work, just want to put a good one on). I ordered one from Black Dragon, but the nut is thicker than the stock nut and larger in diameter. I have checked all the nut and bolt places here in Albuquerque, but no left hand, fine thread metric nuts. Does any one know where I can get a nut that is the same as the original? Also, on the rack there is a plastic grease reservoir on the top of the passenger side of the rack - are these available or is it best to put in a grease fitting? Thanks in advance for informaton on the lock nut and/or the grease reservoir. -Bill- Link to comment https://www.classiczcars.com/forums/topic/11335-tie-rod-help-needed-quick-before-school-starts/?&page=3#findComment-287640 Share on other sites More sharing options...
