.030-.035 is pretty much the standard plug gap. With the electronic ignition you should probably go to .035, even a little more than that if you've done any upgrades to the ignition like a hotter coil etc....
  • 1 month later...
I have both, Haynes and Chiltons, service manuals. Both list gap for '70-'76 as .030-.035 and '77-'83 as .039-.043. Is this correct? How is it that the FI engines from the '75-'76 would want the same gap as with carbs? I have a '75. When I checked the plugs, they are all gapped at .041-.042. The car seems to run fine (even on regular 87 octane). I tried gapping them at .035 for a few days and it seemed a bit down on power, and my fuel mileage dropped 4-6 mpg, so I put them back. Should I change back to a lower gap?
