rear hatch hinge seals
beandip
Hey All
Wonder if Mike at Banzai is reading this message board discussion and the cogs are turning over. Maybe if enough people line up for them it may be an option for a remake by Mike.
Wonder what Nissan did for the rebuild program several years ago?
I got an email from a guy that said the Isuzu Implse uses a hinge gasket that is vary close and will work. I have to find a dealer to call to see if they have any to look . He said that he thought '80---'83 . If any one checkes it out before I have a chance ,post it. I will just as soon as I can . Thanks Guys ,Gary:classic: Up date . They are from a '83 and are still available . I havent seen them in person but have ordered a set and they will be in on Friday the are just under $30.00 for the set. They come right and left . This is all I know , I have mine and one is intact with a little hole but the rubber is not too good. Good enough to be able to compare . I will let everyone know what I find out. :classic:
I received the ISUZU gaskets and they are about 1/3 the size of the Zs . Not even close. Back to the drawing board. I am going to try and repair mine and also make my own. I will post what comes of the latter option. Thanks to every one and if you come up with a sorce from a different breed of car that will work , pass on the info. :classic:
Originally posted by Bambikiller240
Just did a search on "Datsun 240Z" and looked through 10 pages of stuff. Couldn't find them.
Damn, I can't find them either. The auction must be over or have been ended by the seller. Sorry, now I wish I had remembered about this thread when I saw them. :disappoin
I try to keep up with all the new Zcar oriented e-bay listings, and I didn't see them. I would have snatched them up in a second, just like the last set went in a matter of minutes, apparently.
