Posted April 21, 200420 yr comment_78145 Hey guys, you know the dashpot? the thing above the throttle body. is their supposed to be a tube attached to the top of it? plus, what is the purpose to this anyways?. Thanks. Link to comment https://www.classiczcars.com/forums/topic/11379-dashpot/ Share on other sites More sharing options...
April 21, 200420 yr comment_78150 On what engine? Link to comment https://www.classiczcars.com/forums/topic/11379-dashpot/#findComment-78150 Share on other sites More sharing options...
April 22, 200420 yr Author comment_78167 An l28E in my 1978 280Z Link to comment https://www.classiczcars.com/forums/topic/11379-dashpot/#findComment-78167 Share on other sites More sharing options...
April 22, 200420 yr comment_78172 I can't help you. Both of mine are 240 or 260.Having said that it could be throttle opener for the A/C.Part of the anti back fire system or any other zany emmision control device you care to think about.Best advice is to get a FSM, it will save you much fustration. Link to comment https://www.classiczcars.com/forums/topic/11379-dashpot/#findComment-78172 Share on other sites More sharing options...
April 22, 200420 yr comment_78173 No tube attaches to the top of the dashpot. There is a white plastic cap that is usually broken or missing that screws on to the top of it. It's emission control related and supposedly reduces CO at idle. Only the manual trans cars had them. The FSM doesn't really get into much of a description of its function. It only talks about adjustment. Link to comment https://www.classiczcars.com/forums/topic/11379-dashpot/#findComment-78173 Share on other sites More sharing options...
April 24, 200420 yr Author comment_78402 Thanks alot, its just that white cap makes it look like its missing a tube. Link to comment https://www.classiczcars.com/forums/topic/11379-dashpot/#findComment-78402 Share on other sites More sharing options...
