Posted April 24, 200420 yr comment_78393 Hey does anyone have any door panels for a 1980 280Zx. The interior is blues perferably, but I think I can paint over the vinal if its another color. I need them with no cracks. Let me know if you have any, and or if you have any Ideas on how to redue them. Im looking also for a carpet for the back hatch Thanks Steve Link to comment https://www.classiczcars.com/forums/topic/11411-i-need-door-panels/ Share on other sites More sharing options...
April 24, 200420 yr comment_78398 New Door Panels are too much money. Why don't you just replace the vinyl on the door panels? It is pretty easy to do. Will Link to comment https://www.classiczcars.com/forums/topic/11411-i-need-door-panels/#findComment-78398 Share on other sites More sharing options...
April 27, 200420 yr Author comment_78718 any Ideas on how?? Link to comment https://www.classiczcars.com/forums/topic/11411-i-need-door-panels/#findComment-78718 Share on other sites More sharing options...
April 27, 200420 yr comment_78732 Originally posted by hls30.com Why don't you just replace the vinyl on the door panels? I thought the door panels on a 280ZX were made out of velour or something like that. Link to comment https://www.classiczcars.com/forums/topic/11411-i-need-door-panels/#findComment-78732 Share on other sites More sharing options...
April 27, 200420 yr comment_78757 The door Panels are chipboard and steel, just like those in the S30. 1) remove the door panel trim. Lock switch and window switch trim pry off with a screwdriver, the door handles have bolts that are removed with a phillips screwdriver or a 10mm socket. 2) Use a putty knife(or large standard screwdriver) to gently pry the door panel off the door. Start at the lower edge and work around the door. The Fasteners are located on the bottom and the sides of the door panel, when all are free, gently lift the door panel up and off the door.3) The upholstery on the panel is glued and stapled. Use a small standard screwdriver to remove the staples from the back side of the panel. When the staples are removed, genlty peel the upholstery off-keep it intact if you want to use it for a pattern.All traces of foam should be removed-glue doesn't retain adhesion to old crumbly foam.4) Get some new upholstery material from a cloth store.5) Get some 3M Weldwood (red can)and some cheep natural fiber paint brushes, and a lineoleum roller.6) Trim the upholstery to fit the panel-the top seam is tricky. Brush glue on the door panel and the underside of the upholstery-give it a few minutes to thicken, and place it on the panel and roll out the bubbles.7) trim the opening s for the switches, and holes for the door handle bolt.8) Put the panels back on, fasten all of the fasteners.9) Take pictures of your work and post them to your gallery10) Post to this thread again to tell us you are finished.Post if you get stuck or have questions Link to comment https://www.classiczcars.com/forums/topic/11411-i-need-door-panels/#findComment-78757 Share on other sites More sharing options...
April 28, 200420 yr Author comment_78930 Thanks for the info guys, I will keep in touch if I have anymore questions. I cant start the project right away because my scedual is crazy. I will have to do it after school lets out. Thanks again, Steve Link to comment https://www.classiczcars.com/forums/topic/11411-i-need-door-panels/#findComment-78930 Share on other sites More sharing options...
