  • 4 weeks later...
A PAVLICK:
From your post it apears you either didn't open the web site or your browser won't let it open. There are lots of pictures. Car is in Portland, OR. Interior looks great and it looks like it has a perfect dash, something one rarely sees in an old Z. I didn't see an asking price. This looks like a car that could be really nice with just a little spot rust repair.
Here the details from the ad:
This is my 1971 240Z for sale
Located in Portland, OR
Note, Large pictures takes some time to load.
Details:
Daily driver
109K miles on original Motor
Recored Radiator
New after market fuel pump
New Nissan rubber hoses in engine compartment
New Nissan soft break lines (not installed)
New Tires Les Schwab(1k miles on them)
New clutch, after market, less then 1K on it
New throughout bearing
Rear breaks gone through
1/2 shafts solid
Tags good to 02 2003
Does not burn oil or smoke
Previous owner has receipts since car was purchased new, I am trying to get them.
Needs a bath
Interior, Red, all pieces there, good to great shape:
Original Dash, no cracks
All gauges work, clock is intermittent
Original radio, works
Power antenna, works
All lights work
Rear defroster works
Original carpet, in good to great shape
Seats good, 2 small tears, could use more padding in drivers seat
Extra set of red seats, great padding
Floor boards solid, no rust
Rear spare tire area clean no rust (dirt is from noise absorbing material, under carpet)
Good spare tire
Original key
Body, White:
Car has not been wrecked
Paint good, could use repaint after repairs, has only been painted once before
Frame rails strait and solid
One quarter size hole under battery, rust cut out so no futher damage could be caused
Hood:
Rock chips
Small dent in nose
Passenger side:
Top of fender has small rust holes
Bondo spot in lower fender (see pic) both bolts still good
Slight rust in front of rear tire rocker, looks like surface rust
Driver side:
Top of fender has small rust holes and some old repair work with repaint in small section
Bottom of rear of fender is solid
Rocker in front of rear wheel needs replacing
Hatch:
Surface rust in lower passenger corner, otherwise looks great:D
