How about trying to make one?
Doesn't seem to be too complicated. Its a 2-3 mm thick sheet of hard plastic with some louvres in it and a couple of flat rubber doors on the rearside?
Or perhaps it is more complicated than it looks?
I've never seen one of these close up - mine was missing when I bought the car and there are not many of these in the UK. Can somebody please post a good photo and/or supply a dimensioned pattern please ? I presume that the surface finish is similar to that on the interior quarter panels ? Thanks.
Doug
As far as I can see the 'non return' bits' are the rubber flaps attached to the inside of the panel, so fumes can exit the car, but any fumes trying to get back into the car push the rubber flaps shut and stop the fumes. No more complicated than that.
I'll post the pictures later on. I hope they will help.
regards
Andrew
Your explanation is correct, Andrew. I don't have pictures of mine, but that is how it works. Louvers in the panel, rubber flaps in a steel frame attached inside. Please ask Santa to bring me a brand new one in Butterscotch ROFL ROFL ROFL
  • 1 month later...
