Between work, school and planning a wedding I dont have time to compete this project so i am selling it.
The bad...
- needs paint (has some minor surface rust, original looks like it was brown)
-needs interior work(carpet pretty much gone, dash is cracked) -needs hard brake lines up front(just the short ones between the caliper and brake line)
The good...
-runs good
-has dual weber dgv's
-no body rot
-front suspension rebuilt(new tokico struts and shocks, 4 piston calipers, urethane bushings, stainless steel brake lines, new ball joints and outer tie rod ends)
-I have new tokico struts and springs for the rear as well
-seats were recently reupholstered
The hood and front fenders are off the car and it will obvioulsy need to be towed since the front brake system is not complete. It has a manual transmission. Like to sell it locally in the bay area. I will post pics very soon. Make an offer.
https://www.classiczcars.com/forums/topic/11479-1973-240z/
heres a more detailed list of some of the items that have been installed:
Tokico blue struts and springs. (only installed on front)
Toyota 4-piston calipers.
Stainless steel brake lines.
Rebuilt starter.
New K&N air cleaners.
New battery terminals and cables.
Urethane steering rack bushings
All new tension rod components
New outer tie rod ends
New lower ball joints
Urethane control arm bushings
new steering coupler
bump steer spacers (not installed but will include)
https://www.classiczcars.com/forums/topic/11479-1973-240z/#findComment-83894
