Hi all.
I was just wondering what performance upgrades you have done to you L series engine, the price and power gain. I was just wondering because I can see me getting a Z fairly soon.
Cheer'z'
Chris
https://www.classiczcars.com/forums/topic/11494-your-performance-upgrades/
OK, here is what has been done to the 77 280Z in the avatar......
*Completely rebuilt L28 FI engine balance & blueprinted
*Computer balanced & lightened Flywheel
*40 overbore with new Flat Top pistons & rings
*Ported & polished head with a 5 angle cut valve job (all stainless steel valves)
*Head shaved
*460 Schneider Racing Cam
*60 mm Throttle body
*Mallory Unilite Distributor with 8.5 mm MSD plug wires on NGK plugs
*Crane PS-40 Fireball Coil
*Rising rate fuel pressure regulator
*All filters are K&N
*4 core radiator with Cool Flex hosing, including heater hoses
*6 into 1 Jet Hot coated header with 2 1/2" custom bent aluminized exhaust with a #304 stainless steel Powertone muffler with dual horizontal Borla tips
This is what I know has been done to the Z but Scott could probably provide more technical info.
Vicky
