Those are well-regarded struts but I'd be curious about the rest of your suspension. Lots of things can contribute to a harsh ride such as tires (especially big rims with low profile tires), springs, bushings, etc. Also, keep in mind that what might seem harsh to you might be considered normal for a 240Z.
Another thing that you might not have even considered is that the padding in your seats may need replacing.
https://www.classiczcars.com/forums/topic/11514-shocks/#findComment-79167
  • 1 month later...
Speaking of struts, has anyone here used the Edelbrock IAS struts or shocks? I am not even sure iof there is an application for the Z cars, but supposedly they are anice setup, firm but comfortable over the bumps. IAS stands for Inertia Active System I beleive. It has to do with the valving design and mechanism.
What do you recommend for an otherwise stock car in terms of ride height and suspension?
Todd
https://www.classiczcars.com/forums/topic/11514-shocks/#findComment-83849
  • 7 years later...
It's been a while since I have posted here.
The struts that I have are KYB G-2. I am vary satisfied with the ride. It is firm but not harsh, I also am running
Euro stage l springs that I have cut to lower the car. They are not a progressive coil spring so cutting them doesn't change the stiffness. Just this past weekend we drove to the Coast and on some vary twisty back roads 260 miles and they are still working great. I have had this set up installed for about 4 years now and I wouldn't change a thing. On the hwy and normal driving the ride is great. I only bottom out on severe bumps but with the bump stops on all
four corners it's no problem at all.
Hope this helps.
Gary
https://www.classiczcars.com/forums/topic/11514-shocks/#findComment-363255
Necropost of the day! This thread is over 7 years old...
  Quote
It's a coil spring. If you cut a coil off, the spring constant (stiffness) will increase, no matter if it's progressive or linear.
k= (G*d^4) / (8*n*D^3)
k - spring stiffness
G - a constant dependent upon material used
d - wire diameter
n - number of "active" coils (this varies with the type of spring ends)
D - average coil diameter
Therefore, stiffness increases as you decrease the amount of coils, increase material rigidity, increase wire diameter, or decrease average coil diameter.
https://www.classiczcars.com/forums/topic/11514-shocks/#findComment-363268
Good to see you back, Gary.
d - wire diameter
I'll agree in theory. But I have the same springs as Gary, and I also have used them on the same car both before and after cutting them down. The difference in stiffness was negligible. No difference in ride stiffness. I'm going to guess that while the spring rate may have increased, the preload decreased (due to the shorter free length). Appears to have been a wash.
https://www.classiczcars.com/forums/topic/11514-shocks/#findComment-363280
Preload? Stiffness doesn't depend on preload...
You can't rely on your "butt dyno" to say there was no difference. Unless you put the springs in a spring tester, you can't draw that conclusion. Depending on how much the springs are cut, the increase in stiffness may not be drastic but it will increase nonetheless.
https://www.classiczcars.com/forums/topic/11514-shocks/#findComment-363345
