I also have been nursing a cyclic howl from the backend on my 1971 240Z. I believed it to be the differential but when I pulled it apart last week found a very rough noise from the rear wheel identified after disconnecting the axle shaft. Source was the outer bearing on the stub axle. Rough universals in the driveshaft or axle shafts may also generate a howl or clunk.
https://www.classiczcars.com/forums/topic/11518-howl/#findComment-79408
